Well literal 12V is not the average voltage over the whole discharge cycle.
Best to use Ah as the canonical unit, Wh does not really accurately reflect the cells' internal chemical processes.
But even using 13V the outcome is a healthy pack, right?
John61CT wrote:Well literal 12V is not the average voltage over the whole discharge cycle.
flboy wrote:Tim,
Do you have an Epever solar controller? I am assuming so since you mentioned the MT50. In any case, they work well for LiFePo4 if you program it properly. Battleborn has the settings you would need on thier website. I am using those settings and solar is charging well.
