TD4FREEW/CTD wrote:keep in mind that the proper function of a GFCI breaker or outlet is dependent on a GOOD functional ground. without proper grounding a GFCI is USELESS!
TD4FREEW/CTD wrote:
one idea is to attach a ground strap to your vehicle. it might be an idea to use a 3'-4' conductive, preferably copper, rod. use a peice of stranded armored ground cable and attach it to your ground bus. drive the steak into soft, moist ground and it should provide a decent ground. you could even moisten the area yourself before driving the rod. as a test you could check for voltage between your ground bus and the campgrounds power before you hook up.
angib wrote:You may want to check and perhaps correct this statement. As I understand it, your GFCI works exactly the same way as our RCD (residual current device) - they're the same devices with different names.
The GFCI simply compares the current flowing in the line and neutral conductors and, if it finds a difference, it trips. The only need for an earth is to make the 'Test' button work - it is not needed to trip the GFCI.
Providing protection where the earth is missing or damaged is an important part of the reason for using a GFCI/RCD.
Andrew
WarPony wrote:Man, I'm going to ditch all the 120V plans on my TTT now. This is too much crap to deal with and I wanted to keep it simple. I am glad that this has gone so far. I might have been injured/killed in my ignorance of campground outlets and bad grounding procedures. I did buy and outlet tester on Sunday but it doesn't test for the quality of the grounds or combinations of defects.
