mikeschn wrote:How long would it take to recharge your teardrop battery if you just started your car every morning and idled it?
Hi Mike
A car alternator without a smart regulator will never recharge the battery, see the links above re smart regulators look at the graph for alterantor only charging.
Steve H
Not if the alternator is powering the vehicle starter battery once the engine is running the starter does nothing.
Steve read the links I added above a standard alternator is not a good charger in fact it is an extremely poor charger, its a power supply thats its Job. it just happens to replace the tiny amount of charge lost when starting a vehicle battery doesnt ever get above 65-70% charged.
Regarding output look at the graphs again, as a batteries internal resistance changes the charge current drops rapidly, it rarely puts out more than a few amps except in the minute after starting.
All this is very hard to explain to electrical techies (I have even had to physically demonstrate to some to prove all this happens)
Hi sdtripper2
Thats all OK for vehicle system, not that good for a leisure (or deep cycle) situation, the system as described works for starter batteries that dont ever need to be fully charged and only ever supply a tiny ah for starting the vehicle. And note that that regulates the Voltage the ampage is only controled by thevariable resistance of the battery drawing the current.
Chris C
for CPap and that amount of current draw we need to design a better system.
I am about to go out, but I will sort exactly what you need later and I will guarantee that what I say will work exactly as I say it will.
and after replacing 3 in a 5 year period, I'm convinced automobile alternaters are for starting batteries, not deep cycle.
More evidence that what I say is right, if every ones got a few months I can explain every stage of what goes on in these systems
If you want, we should start a seperate thread just to discuss the system you need
