StandUpGuy wrote:... It seems that there are several short comings in all of this. One being that it needs to be set up at campsite each time and two, being that the restriction of the hoses creates a flow problem. Obviously all of this is to try to eliminate some of the bone rattling noise of an AC in a small trailer.
I am trying to work out a different version where the window AC unit is permanently housed in a tongue box with some sort of sound buffering short ducting perhaps made of soft rubber. The storage box would also need to be somehow insulated from the trailer frame to further reduce vibration and noise. The controls would need to be rewired to be inside as you have done. Is it possible to greatly reduce the noise this way?....
Didn't hack my A/C, but mounted on the rear bulkhead between cabin and galley. Firmly mounted, with no rattling nor
noise.
- definition of noise.JPG (43.66 KiB) Viewed 2073 times
Of course, the humming drone of the A/C compressor is virtually a "white noise" that helps me sleep, by covering sounds from outside the cabin, and partially obscuring my tinnitus. Ever since we used window units back in the 50's thru 70's, I always regarded the sound of running window units as soothing. Maybe it's just my opinion.
Instead of putting my A/C unit outside in the elements, subject to damage, theft, or possibly a short circuit (of the controls), I did a different "hack" by making my A/C exhaust exit to the side thru ducting, and I can close and lock my galley hatch while it's running overnite. Sure, it takes up a lot of galley space, and I'd probably route the exhaust straight back thru the hatch instead of at a right-angle, but there's been no problems (nor flow restrictions) to worry about, for nine years of use.
https://www.tnttt.com/viewtopic.php?f=21&t=54945&hilit=+ac+install
