Inverters
Postby TonyCooper » Sat Apr 02, 2005 11:37 pm
TomS wrote:I picked up a 350 Watt inverter for my tear. I'm also making provisions for using shore power, when available. I plan to install a GFCI.
I have some a questions.
1. Will a GFCI work while connected to the inverter?
2. Do I need to even worry about GFCI protection while running such as small (350 Watt) inverter?
1) Yes
2) Yes
GFCI protects people... Circuit Breakers protect wires... You need both.
My Tear Build Site
"No comment"
TonyCooper
Official Pot Stirrer
Images: 35
Postby asianflava » Mon Apr 04, 2005 12:55 am
Ok here it is. Now keep in mind that this is not a schematic, it is a diagram so I know what goes where. The wiring is not compelete as the DC circuits don't show the ground.
asianflava
Postby TonyCooper » Mon Apr 04, 2005 9:02 am
I'd run the charger directly to the battery, not thru the master switch and fuse. Of course you did say it was not a schematic. And I would think the master switch needs to be b4 the fuse block as well.
My Tear Build Site
"No comment"
TonyCooper
Images: 35
Postby asianflava » Mon Apr 04, 2005 1:51 pm
Thanks, I didn't see that. Actually it wasn't complete, it was mainly a diagram for the AC side. I had to connect a few lines before I posted it. Heh heh what good is a master switch if it is after the fuse block? :?
asianflava
Postby bdosborn » Mon Apr 04, 2005 2:24 pm
I don't see any problem with wiring the battery charger to the fuse block. Keeps your fuses consolidated and keeps a wire off the battery. I guess it all depends on where your charger will be located. Mine is close to the fuse block so I took it there.
Images: 777
Postby TonyCooper » Mon Apr 04, 2005 7:40 pm
bdosborn wrote:I don't see any problem with wiring the battery charger to the fuse block. Keeps your fuses consolidated and keeps a wire off the battery. I guess it all depends on where your charger will be located. Mine is close to the fuse block so I took it there.
The fuse block isn't the issue, it was the master switch and master fuse that I was pointing out. I just stated it poorly.
I'd connect the charger between the battery and fuse. I'd also move the master switch before the fuse block. I'd want to be able to charge my battery without the master switch being on.
My Tear Build Site
"No comment"
TonyCooper
Images: 35
Postby Woody » Mon Apr 04, 2005 7:49 pm
Tony,
That is the way I hooked my charger up. Directly to the battery and the master cutoff at the fuse panel. That way I can charge my battery and shut down the rest of the trailer 12 vdc side
Woody
E-mail: [email protected]
Woody
Images: 26
Inverter powers charger????
Postby Guy » Mon Apr 04, 2005 8:09 pm
I just do not get the inverter powering the charger?
It seems it would really gop like this???
Regards,
Guy
Guy
Images: 44
Postby Woody » Mon Apr 04, 2005 8:17 pm
It is not suppose to, normally. I didn't get it either.
Woody
Woody
Images: 26
Postby TonyCooper » Tue Apr 05, 2005 12:00 am
It doesn't... 110V inputs flow in through the outside pins of the DPDT switch and out through the center line of the switch. This creates a 110v shorepower OR inverter situation. Inverter should only be available when on battery and feeds only his 110v outlets & Nuker (microwave).
The 12V lines from the battery are inputs to the inverter.
The single line coming out of the top of the inverter represents his inverter 110v output lines, both hot and neutral.
I think he has the inverter wired correctly... for simplicity's sake, he's just not showing all his 110v output lines.
My Tear Build Site
"No comment"
TonyCooper
Images: 35
Postby Arne » Tue Apr 05, 2005 7:55 am
Does anyone know if solar panels are equiped with diodes to keep current from back flowing during cloudy periods, or can't this happen...?
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby Arne » Tue Apr 05, 2005 8:56 am
My 500 watt inverter came with double 30 amp fuses. Since I'm running 12 guage wire from the battery, and only a single 30 amp fuse, I figure the most I can pull from the inverter is about 350 watts.... be aware of the wire limitations that you are using.... There is a lot of useful information on the placard that comes with the inverter...
Arne
Mr. Subject Line
Images: 96
Postby Woody » Tue Apr 05, 2005 9:43 am
Arnereil,
Some panels come with the blocking diodes. I have seen the sold separately in the West Marine catolog. If you purchase a good controller they have them built in as well. With out a controller, at night the power feeds back to the panel without blocking diodes installed
Woody
Woody
Images: 26
Postby Arne » Tue Apr 05, 2005 3:10 pm
My inverter is installed... when I wire it up, the green power light comes on (the inverter switch is off). Does this mean it is drawing current, aside from the led? I'd rather not bother hooking of another off on switch just to shut it down completely.
Arne
Mr. Subject Line
Images: 96
Postby Arne » Tue Apr 05, 2005 6:17 pm
Inverter installation..... lots of wide shevles, no cabinets...
Arne
Mr. Subject Line
Images: 96
