LED tail light problem (revisited..... not fixed after all)
Postby jplock » Sat Feb 17, 2007 12:48 am
Warpony,
Have you checked to see if the trailer wires are crossed. To check unplug from tow vehical disconnect the lights ( remove bulbs or LED's). Using an ohm meter you should see no continuity between wires. As example ground to Right turn, right turn to left turn, Left turn to Stop, right turn to stop, stop to tail, etc.
jplock
Keep smiling!
jplock
Images: 233
Postby WarPony » Sat Feb 17, 2007 3:32 pm
jplock wrote:Warpony,
Have you checked to see if the trailer wires are crossed?
Yes, I thought of that early on into the addition of the lights and checked to make sure I didn't goof up.
WarPony
Images: 289
Postby Arne » Sat Feb 17, 2007 7:01 pm
Have you checked the voltage at the light? This sure is a quandry.
I'm still thinking a bad ground somewhere.
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby Steve_Cox » Sat Feb 17, 2007 8:11 pm
Micro469 wrote:ScotchLocs, if you are referring to those little round connectors with goo in them are made for SOLID wire IDC connections . They are NOT made for stranded wire...... 8)
John,
They are referring to a 3M product that relies on little metal forks to penetrate the wire insulation and make a compression connection with the conductor between the forks.
Steve_Cox
Images: 196
