Dear,Jim, Paul, George, Boodro others
My sense of humor has no place here so please excuse it's loss.
Unless I totally read Endo's post wrong, this is a fountain pump. It is intended to circulate water in a fountain. I am willing to bet it has a disclaimer on it to not stand with your hands or other body parts emmersed.
George I have tried to agree with you this whole post, you don't read it because you are not seeing that the words grounded and earthed are the same. In "Electrical " you agreed to test the power plug being used to be sure it is earthed. I will not disrespect you on this forum and I would appreciate it if you would try to do the same.
You are not an electrician in America. I don't have electricial experience with 12v. My husband who read this thread and walked off shaking his head has over 30 years in the wholesale electrical business. He knows our code inside and out. He has been to every school to update his knowledge every manufacturer he sells for offers. He is the person they call when the electrician needs a fix or to find a way to make something work. He is also qualified on PLC's. I won't give you his full resume because you will not recognise half or what is on there. He does not argue with anyone because he is sueable. I am not and I have not represented myself as an expert but I do know
if you use anything with electricity in a way it was not intended on a source you have not checked you will someday be a nominee for the Darvin award.
You are not an expert and you have told people there is no danger in using something for which you have not seen nor read the first thing on. That should be enough for anyone to heed the advice of the "Electrical code" and read the package directions.
Harbor Freight has a technical help sect. Please call and ask before you use this pump.
The risk for any 120v pump immersed to pump water to the sink is small unless it has a short or the campground is not correctly grounded. Unless someone digs up what they think is an expensive piece of 8 foot copper and sells it. (It is copper clad steel for those who didn't know.)
You don't get "do overs" with 120ac. You die and dieing ain't living.
FYI I will not hook my gas tank to a campground outlet. It has a 12v dc pump and is in a vaccume.
Also: When I said I would not drop a live wire down a loo, everyone missed it. The loo is ceramic one of the best insulators of electricity. You will still die if you Pi$$ in it.
Reguards
