NightCap wrote:How can I use my 12 volt converter to charge my battery safely? My battery charger from harbor freight is making a bad bad noise now. I have a really good converter that could charge the battery pretty good if I can do it without blowing up my battery. Is there an inexpensive way to protect the battery from overcharging?
halfdome, Danny wrote:NightCap wrote:How can I use my 12 volt converter to charge my battery safely? My battery charger from harbor freight is making a bad bad noise now. I have a really good converter that could charge the battery pretty good if I can do it without blowing up my battery. Is there an inexpensive way to protect the battery from overcharging?
Nightcap, I'm not really understanding how you could charge your battery with a converter but a good way to charge without over charging is to use one of these.There is also a 5 amp model if you prefer it. Danny
