Hi All, this is what I have been up to reciently.
I have posted two of the components which I thought others may be interested in in more detail elsewhere on this forum.
I wanted to keep my power requirements low key and low voltage. I wanted some lighting (12V or 5V) a small battery driven hi-fi (2xAA batts =3V), to charge my mp3,phone,palm (5V mostly charge off a computer USB) and to drive a solar powered extractor fan when there was no sun (1.2V).
It should run from 2x7Ahr batteries, must be small, serviceable and fused. I can use Batt No1 or No2 and charge batt No1 or No2 indipendently.
This is my Battery charger it’s an LM317 giving 13.8V current limited to 300mA. It also has a thermistor-controlled fan, which only comes on when things get hot.
This is my voltage board. It takes 12V ish and gives out 2 Amps of 5V which can be cut down to 3.3V and 1.2. Notice the USB headers.
I have a PDF of this schematic so you could read it better but no where to put it to link too.
I have now fitted it to the TD and it fits just fine. Now for that kitchen I must get a couple of sheets of 8'x4'x1/4" Beach ply.
Clive
