I had a few folks ask me where I got the Power Inlet for my TD, so I thought I should post it in case others would like to know. I found this part/info somewhere here on the forum long time ago.
I bought this inlet from the Bass Pro Shop online. Bass Pro Shop
It's $14 and a good deal. I used a 2" hole saw (they say use 1 7/8") and used the screws provided to install. My 3/4" side wall was to thick to use the nut thingie ??? on the back side. (I don't know what it is called) I put a bead of silicone around it just for added protection from leaks.
I wired it straight to a GFCI receptacle and daisy chained the other receptacles to it.
Mary K.
