IF fuse assembly is in enclosure, I see no reason to not solder it. An
exposed buss bar inside a enclosure is not a problem...
Using multiple loops from connector to connector just makes for more places for mechanical connectors (push on) to fail .... But there are also times when it is only solution.
I'll go along with IndyCubby on the ATO/ATC fuse panel style. The built in buss bar is a plus and the blade type fuses (ATO/ATC) are a lot easier to work with. Some of the blade type fuse blocks also have additional GROUND buss bar included. There is also a type of blade fuse available that has a LED included in its construction and it lights up (indicates) when fuse blows...
http://www.waytekwire.com
Part numbers #46280 (3 Amp) through #46289 (40 Amp)..
Also order paper catalogue while at their site.. Below is another site to order catalog from....
https://www.delcity.net/
Some of these sites have minimum Internet order of $25 but if you plan on getting fuse blocks and spare fuses and wire and grommets and what-nots the minimum should not be a problem...
Dale
