Howdy folks!
I have attached the skin to the inside of my hatch. I did this with SS screws and finishing washers. I want to be able to remove the skin if I hava to. I had the leftover scrap from the exterior skin and ended up using 2 pieces for the hatch. I will have a piece of molding to cover the seam.
Skin not attached in this photo.
I had a problem with the break/turn lights I installed. The 3 wire pigtail plug stuck up to far and the skin would not lay flat.
So I got to thinking and sacrificed a pigtail to see if my idea will work. I boiled it in water to soften it up and carefully cut the wires and terminals out of the plastic. Then I put some heat shrink on the wire around the terminal and pluged them in to the sockets. Then filled the socket with silicone.
Sorry, I didn't take a picture of the pigtail before, But this is what the pigtail looked like)
It works good for installing the skin, but I don't know yet if the lights will work....wish me luck.
Mk
