Inverter question
Inverter question
Postby Airspeed » Mon Jun 18, 2007 10:56 pm
My daughter bought me a 200 watt/400 watt max inverter for fathers day, My question is it OK to use this with just my camper battery to run a boombox,small TV/DVD player,small laptop etc. will this run my battery down fast ? I would only be using one device at a time. I read somewhere that it's not good to use an inverter unless it is hooked up to a running vehicle. I would be using it in my tear with just the 140 amp deep cycle battery. Thanks! Aaron
Airspeed
Images: 16
Postby Tear Les » Mon Jun 18, 2007 11:14 pm
Aaron,
I would say a very large number of inverters don't get used when the engine is running. You'd only have to do that if you were pulling down you battery too fast.
At 200 watts you'll consume about 17 amps on the DC side; your 140 AH battery would be good for about 4 hours at that rate if you wanted to keep your battery above 50% depth of discharge. Take a look on the labels of the things you want to run; they'll normall have the wattage or amperage draw on them. If it's watts divide by 115-volts (usually what they're rated at) to get amps. Multiply amps by 10 to get from the AC side draw to the DC side draw (this also takes into account the loss in the inverter). If your battery is fully charged you'll have about 70 AH to use to stay at the 50% or better mark (you can go lower depending on your battery but you don't want to suck it all the way down).
If you're running a 60-watt light bulb for instance that's .52 amps on the AC side (60/115) and about 5 amps on the DC side (.52*10). You can keep that puppy going for 14 hours!
Hope this helps.
Les Lampman
Tear Les
Postby ARKPAT » Mon Jun 18, 2007 11:31 pm
I have a HF 140 watt inverter ( cigar plug one ) with one outlet. It pulls about ONE AMP without anything attached ( the inverter fan and cicuitry draws about that ) then the total wattage as described above. :cry:
:thinking:
I was supprised, also then remembered ( idle current for the inverter that all have to keep them running when nothing is attached ) the hidden current it was using. So you might want to figure that into the time running. :thumbsup:
Some inverters say how much Idle wattage or current they comsume with nothing attached.
:thinking:
Pat
ARKPAT
Images: 77
