Maybe it the DOS, and the WWWLX browser!!! It just doesn't cut it...
LOL
toypusher wrote:This time it worked.![]()
Comments?
Guy wrote:Dear Joanne,
What program did you use for your wiring diagram?
toypusher wrote:Comments?
angib wrote:toypusher wrote:Comments?
Kerry,
Electrically, this looks fine.
But, from my international perspective, I can see a political problem. Looking at your illustration it is apparent that you intend to get your master switch and selector switch by stealing these discontinued models from the wall of Dr Frankenstein's laboratory. This is going to have a fairly severe impact on the Transylvanian labour market and may lead to an offical complaint from the Romanian government.
I recommend you purchase new switches from any reputable electrical supplier.
Andrew
toypusher wrote:Hope the new drawings (1 with and 1 without the battery charger) will meet with mass approval![]()
Kerry
bdosborn wrote:
I'm confused after looking at the wiring diagram some more. Usally, a 12V converter charges the battery as well as supplies the loads. There's no need to use a seperate battery charger. The selecter switch as shown ensures that the converter will never charge the battery, which I don't think we want. Did you mean to show wiring for an invertor instead (12VDC to 120V AC)? If so, the selector switch would shut off the 12v power whenever you used it. If it is a convertor you can ditch the selector switch. If its an invertor, I'd move the selector switch to the 120V output. I can mark up ypur drawing and send you a PDF if that would help.
