Slowing down a FantasticVent
Re: Slowing down a FantasticVent
Postby MtnDon » Wed Jan 06, 2016 2:33 pm
A further thought on the wall mounted touch type dimmer... My experience with another DC touch dimmer indicates it has a low draw all the time. The unit I have draws zero after the power is switched off and back on. But as soon as the control is touched it has a continuous draw to remember the last used setting. It is a low draw, but I have never metered it. I do not believe it would be a concern in ordinary use. However, when parked and stored I don't know.
MtnDon
Images: 24
Postby dales133 » Wed Jan 06, 2016 4:32 pm
Id agree with you mtndon on tbe chinese componants.
Ive recieved stacks of small electrical and other parts and if your prepared for a verry small percentage of duds you can save alot of money
dales133
Postby vegask » Fri Mar 25, 2016 4:25 pm
Just tried two different PWM controllers that were on amazon, both by RioRand. One had a reverse option, the other did not. The one with the reverse option made a ton of high freq/high pitch noise at low speeds. The non-reverse model made a grinding sound in the fan motor at low speeds. So both are on their way back to amazon, I have a 50ohm 25 watt rheostat on order I will try next.
Video of the reversing pwm model I tired.
https://youtu.be/PCuJ_Mj9-lQ
vegask
Postby rbtrary » Tue Mar 17, 2020 3:27 pm
Here's a video of 50 ohm 25 watt rheostat for variable speed control on Fantastic Fan. replaces the fixed 3 speed switch. on/off using in/out switch. super slow and quiet, mid speed and full speed.
https://youtu.be/c-1LE5NNfGM
rbtrary
