AC Electrical System in the Zephyr TD Part 1
Postby Dee Bee » Tue Apr 12, 2005 12:13 pm
Hi Zephyr Fans,
Some of you have emailed me saying how you appreciate the pics I post on my progress. I hope it either entertains you and you write to me about a better way to do what I am trying, or it helps you to try your hand at a TD.
Monday I had another chance to work on the Zephyr. Here are the pics.
http://www.nfdc.net/home/cbdb/Micro%20CamperElectric.htm
Comments welcome and appreciated.
DEE
Grace happens...
Dee Bee
Images: 55
Postby Guest » Tue Apr 12, 2005 12:27 pm
Dee,
Thanks A Lot!!!
I'll be watching this thread, that's for sure.
signed, Electrical Putz :lol:
Guest
Postby toypusher » Tue Apr 12, 2005 3:21 pm
Dee,
You know that 14-2 romex normally is only used for lighting. I am going to go with 12-2, which is the standard for normal household 110VAC wiring. I guess with only 15 Amps it should be OK.
Nice job on the Zephyr.
Kerry
toypusher
Images: 324
Postby Geron » Tue Apr 12, 2005 5:20 pm
Dee Bee,
Where did you find that single breaker load box??
Geron
Geron
Images: 173
Postby toypusher » Tue Apr 12, 2005 7:01 pm
Geron,
I have the same box. I got it at an electrical suppy place.
Kerry
toypusher
Images: 324
Postby Geron » Tue Apr 12, 2005 8:23 pm
OK, Thanks, I'd checked HD and no luck. I'll try City Electrical and Plumbing. :oops: Never crossed my mind :duh
g
Geron
Images: 173
Load Box
Postby Dee Bee » Tue Apr 12, 2005 9:05 pm
Geron wrote:Dee Bee,
Geron
I think I saw the load box at Home Depot. It is rated for 30 amps, there are two breaker slots in the box.
DEE
Grace happens...
Dee Bee
Images: 55
Postby mexican tear » Tue Apr 12, 2005 9:26 pm
I use a two breaker box and switch one on for shore power and the other for the inverter. I have made a slide protection so that only one swithch can be turned on at a time. A home made transfer switch. It works good and allows only one source of 120 to be used at a time.
http://pg.photos.yahoo.com/ph/kailois/d ... pg&.src=ph
kai
"Essie" and the Mexican Tear
mexican tear
Images: 14
