Southern Oregon Bob wrote:I prewired all my walls and I'm set up to have a 3 gang switch at the head of the bed. Fan, 2 reading lights, and the cabin dome. I ran #12 wire in and out for fan and #14 in and out for each light. I went and got the 3 gang switch I planned on using ( 110v 3 rocker switches in a single box. When I got it home it only has 1 hot going in and 3 switched going out. If I used the #12 for the hot in and #12 to fan and #14s to the lights and put them all on a 20amp fuse will that be safe? Will the fuse not brake soon enough if I'm just using a light or is the single #12 not large enough to run them all at once? If I fished in all #12 would that help or do I just need to forget what I thought would be the perfect switch? Sorry that got so long, I guess what I'm asking is, is there is a good way to put two lights and the vent fan on 1 circuit? Bob
Southern Oregon Bob wrote:If a terminal bar is rated for 110v at 20amps what is the formula for converting that rating to 12v at (X)amps?
