webbedouin wrote:One problem you're going to have is that the batteries are going to use the bulk of their power charging each other when wired in parallel, as bat A's voltage drops lower than bat B, Bat B will charge Bat A until it's voltage drops lower than bat A. Then Bat A will charge Bat B. This will go on forever discharging both batteries as the total charge dissipates in the form of heat. You need a battery isolator, on the plus side. Charger goes to the isolator and isolator legs (Input across two big diodes) then to both batteries. That way the two don't see each other's load. The diodes will drop the charger voltage .6 of a volt. It just what diodes do. Don’t know where your 12 volts go from there, but be careful the rest of the wiring does not allow the two batteries to talk to each other.
webbedouin wrote:IMHO you can not get away with anything with your batteries. Oh, it may work for a while, sure, but the only reward you'll ever get is a shorter batter life.
webbedouin wrote:By way of example, my expectations for battery life is three to five years. And i'm using a big Sears diehard that has been in a dual battery situation for 7 years!!!
webbedouin wrote:Have seen some of those banks of batteries and capacitors. When used on a stereo those capacitors can provide that extra punch for reproduction of very loud quick transients. Of course those systems, too, have a charger available, just turn on the engine. And with the monster stereo and the hydraulics, quite the load.
The part that cracks me up is, a battery is essentially a huge large very big assed capacitor. So once you've set up the large bank of batteries, Whatdaya need more capacitors for anyway??? It's like spreading a handful of sand on a boulder field. They sure look Kewl though. But then those displays have a certain amount of conspicuous consumption function built in.
