PcHistorian wrote:@bdosborn: do you have your trailer +12vdc for the battery connected to the tow vehicle's battery or to the alternator output wire, or some point in the ignition switch like an accessory or ignition circuit? (I'd go with ignition, then if you use the accessories on the key switch, you won't connect and drain both batteries. And when ever the car is on and running, then that will be powered to charge the trailer battery.
bdosborn wrote:Cool, make sure and post a review! Don't forget to add the DPDT center off switch so you can have manual control over the combined.
absolutsnwbrdr wrote:bdosborn wrote:Cool, make sure and post a review! Don't forget to add the DPDT center off switch so you can have manual control over the combined.
Why would I need the manual control? The instruction sheet mentions that green remote wire can be connected to a SPDT center-off switch, but is usually left unattached for automatic operation.
