2 power sources for 1 fan
Anything electric, AC or DC
Postby wtcreaux » Wed Oct 28, 2015 9:47 am
I am wanting to power a Fantastic vent fan through my solar controller (load side) (as the day heats up) but also want to be able to run the fan at night when I'm in it.
Question - the only way I can think of is to run 1 power wire (with a diode) from the solar controller to the fan AND 1 power wire (with a diode) from the PD4045 to the fan. It has been a LONG time since I've used diodes......does this sound reasonable??
wtcreaux
Images: 211
Re: 2 power sources for 1 fan
Postby H.A. » Wed Oct 28, 2015 10:42 am
H.A.
Postby wtcreaux » Wed Oct 28, 2015 10:50 am
H.A. thanks for the reply.
My concern is running the fan off the battery when there are multiple days of limited sun (therefore not much solar charging).......I don't want to necessarily power the fan at night, running down the battery.....the trailer resides at a trailer storage lot.....
wtcreaux
Images: 211
Postby troubleScottie » Wed Oct 28, 2015 11:39 am
There needs to be switch between your battery and the fan. The diode just limits the current flow.
Having both connection means power can be taken from either side.
Hopefully when parked you have a switch to disconnect all items in the trailer.
Michael Krolewski
Scottish Terrier Fancier
troubleScottie
Images: 16
Postby jss06 » Thu Oct 29, 2015 9:33 am
Wire it to the battery and feed the battery with the solar charge controller. Just turn the fan off when not in use.
In storage you should not have the vent open anyway. No telling what can get into the trailer.
jss06
Palladium Donating Member
Postby dales133 » Thu Oct 29, 2015 3:52 pm
My fantastic fan has a 1.5 amp fuse,the power consumption should be little
dales133
Postby Dale M. » Fri Oct 30, 2015 6:42 am
jss06 wrote:Wire it to the battery and feed the battery with the solar charge controller. Just turn the fan off when not in use.
Having ventilation controls humidity which prevents mold and mildew.... One of the biggest heath hazards and repair/restoration problems with small trailers...
Dale
Dale M.
Images: 18
Return to Electrical Secrets
Users browsing this forum: No registered users and 32 guests
