Charger or converter?
Postby atcNick » Fri Oct 30, 2015 12:48 pm
I've got a cargo trailer w/30amp 120vac. I'm adding a size 24 battery to power a 12v water pump for a sink only, no shower. And a winch. I'm trying to figure out if I should get a converter, battery charger, or battery tender?
This is a competition BBQ trailer that will be used about 36 hours at a time with occasional use of the water pump during that time and maybe 3-4 minutes of total use time on the winch. While trailer is in use it will be connected to shore power.
Help is appreciated!
-Nick
atcNick
Re: Charger or converter?
Postby Jim.Johnson » Fri Oct 30, 2015 5:18 pm
If you only use the 12 volt while you're on shore power you would only need a converter and no battery. If you want the battery you would want a smart charger that would keep the battery charged while you are on shore power. Since you are plugged in so much of the time it does not need to be a large charger. A smart charger will charge the battery and act as a battery tender just too maintain it when it's not in use.
Jim.Johnson
Postby atcNick » Fri Oct 30, 2015 8:34 pm
Thank you sr
-Nick
atcNick
Users browsing this forum: No registered users and 36 guests
