tony.latham wrote:I'd recheck if the lights are working on your utility trailer. If they do, two-bits says it's a ground issue on your teardrop. It may be that it's only getting ground by the metal to metal connection at the hitch. Or at least that's my guess.
mrredrocker wrote:tony.latham wrote:I'd recheck if the lights are working on your utility trailer. If they do, two-bits says it's a ground issue on your teardrop. It may be that it's only getting ground by the metal to metal connection at the hitch. Or at least that's my guess.
Unfortunately I'm already on the road, so I can't confirm the utility trailer lights (they use a 4pin connection without the adaptor and a separate hitch ball anyway, if that makes a difference). Should I buy one of those light tester gadgets like this?
http://www.walmart.com/ip/16781903?wmls ... 16&veh=sem
Sent from my SPH-L710 using Tapatalk
mrredrocker wrote:
I bought one of those little plug in testers: http://www.harborfreight.com/four-way-t ... 66526.html
Testing the tow vehicle, I notice that when I push the brakes, both lights on come initially, but then the left side starts to blink. Both turn signals appear to work as they should. So I'm thinking it's tow vehicle specific. EXCEPT, when I turn on my headlights, all 3 lights on the tester come on when the brakes are applied. So I don't know. At all.
pchast wrote:With an '07 tow vehicle, Do You have LED lights on the TV?????
Otherwise
You may have a burnt out fuse on the 12 volt supply line to the
Converter that supplies the 4 pole socket.
Dale M. wrote:IS this situation with tester ONLY or with trailer plugged into tester...
If its tester only you have tow vehicle problem, if its only with trailer plugged in its a trailer problem.... If its with tester only, you probably have blown converter in TV...
Dale
bobhenry wrote:OK time for old school...... Drag out the jumper cables and clamp one color only on the tow vehicle frame bare steel where possible. Now take the other end of the same cable and clamp it on the trailer frame bare metal. Dollar to a donut I bet the gremlin is gone !
pchast wrote:No advantage to the powered converter... Its only used for LED systems since the wire sizes and
current values on the TV will not provide enough power for additional lighting.
mrredrocker wrote:The Silver Shadow does have LED lights on it... and when testing my trailer lights with the new harness, while it was the middle of the day, I realized that the trailer lights aren't very bright, especially for LEDs. Wondering if the trailer is getting adequate power.
Users browsing this forum: No registered users and 31 guests
