I have hooked up 2 led lights and a fan to the 12v battery through the circuit breaker and ground block. However I can't get them to work. Am I doing something wrong?
Sent from my SAMSUNG-SM-G928A using Tapatalk
Padilen wrote:Is battery charged?
Redneck Teepee wrote:Some LED's are polarity sensitive.... will not light if hooked up incorrectly, usually the longer lead is positive.
vitya-velik wrote:Padilen wrote:Is battery charged?
Yes I checked. It's brand new. 13.2 volts
Dale M. wrote:Only problem with picture is does not show us anything other you have a battery and some wire and a fuse block and ground block picture is not up close and personal enough to see details....... And I have to wonder if you have ground block wired correctly from what I can see.... Does construction of ground block have one side where wire from battery is connected serve all the ground positions... I know fuse block is "one supply" serves all fuses (because I recognize its design) , but can not see details of ground block...
Also there is a terminology thing here, what you are referring to as circuit breaker is actual called a "fuse panel" or "fuse block" ... But actually serve same function...
Dale
Padilen wrote:vitya-velik wrote:Padilen wrote:Is battery charged?
Good that's step one!
Now as already stated remove everything, test each item- directly with the battery. Then start reassembly.
Good luck
Dale M. wrote:For grounds, just strap all one side common with loops from one terminal to another or run down to local big box store and get a "ground strip"....
Personally I would just strap the one you have...
or
Dale
