How to test a circuit I've wired
Postby szern » Sun Dec 31, 2017 7:55 am
Hello All! I'm totally new to wiring and have been trying my best to learn what I can through this forum & Youtube. I just wired a usb, 12 volt outlet & switch together and want to test it out to see if it works. Is it as simple as touching the + (black) and - (white) wires to my deep cycle marine battery poles? Thanks!
szern
Images: 40
Re: How to test a circuit I've wired
Postby Gettin Started » Sun Dec 31, 2017 9:07 am
That's how i tested my 12v wiring when building my trailer. Touch pos/neg to a small battery and see if it works.
Gettin Started
Images: 15
Postby Dale M. » Sun Dec 31, 2017 9:14 am
Probably as long as you are sure of polarity (colors) .... Got a volt meter?..... Connect it up and check voltages are in correct place for 12VDC accessory plug and USB connector...
USB pin outs...
Might feel more comfortable sacrificing (extra) USB cable for access to power for polarity checks...
Be very careful with probes in USB connector and pins and area are very confined, short it out and probably "POOF" you let the "magic smoke" out...
Dale
Dale M.
Images: 18
Postby szern » Mon Jan 01, 2018 11:19 am
Thanks for your help and for the posted diagrams! It actually worked! I just touched the black wire (+) to the positive pole of my battery and the white wire (-) to the negative pole of the battery and the led light on the switch came on as well as the usb port! I am attempting to post a picture of the wiring as well as a somewhat current photo of my build. I've never posted pics here before so not sure if I will be successful.
152366
152367
szern
Images: 40
Postby tony.latham » Mon Jan 01, 2018 11:34 am
Just in case this thread is viewed by the next builder ––make sure your hot wire is properly fused before you run the test.
T
Postby szern » Mon Jan 01, 2018 1:24 pm
Thanks for the warning Tony. I am just learning electricity and wiring so I can use all the help I can get from you all on this forum. The device is a duel USB socket charger 2.1 amp and 2.1 amp with LED voltmeter and 12 volt power outlet and a switch. From what I've read I should use a fuse that is slightly higher than what the device will draw so do you think a 5 amp fuse would be good to use to test out the circuit. Something like the picture below?
152383
szern
Images: 40
Postby Boatguy249 » Mon Jan 01, 2018 4:41 pm
szern wrote:Hello All! I'm totally new to wiring and have been trying my best to learn what I can through this forum & Youtube. I just wired a usb, 12 volt outlet & switch together and want to test it out to see if it works. Is it as simple as touching the + (black) and - (white) wires to my deep cycle marine battery poles? Thanks!
Yes but you must do so while standing on your head
Sent from my SM-S902L using Tapatalk
Boatguy249
Postby tony.latham » Mon Jan 01, 2018 6:26 pm
The fuse should be rated to protect the wire size not the expected draw. There are lots of charts on what wire gauges will handle what amps with a 12v DC circuit.
Postby szern » Mon Jan 01, 2018 6:54 pm
Thanks again Tony - I'll check it out.
szern
Images: 40
Postby szern » Mon Jan 01, 2018 7:39 pm
Based on this chart I found I should use 15 amp fuses since I'm using 14 gauge wire.
152406
szern
Images: 40
Postby tony.latham » Mon Jan 01, 2018 8:37 pm
szern wrote:Based on this chart I found I should use 15 amp fuses since I'm using 14 gauge wire.
152406
T
