redbicycle wrote:The trailer chassis is often used as a ground. They are likely designed that the mounting screw would be grounded to the metal chassis. It is easy to test by running 12v+ to the one wire and - to the metal trim of the light. If you have illumination you can either screw the lights into the metal chassis, or use a crip on end on a wire and run that under one of your mounting screws.
Benno wrote:Pretty sure he said he has a wooden trailer.
Sent from my ZTE T84 using Tapatalk
Shadow Catcher wrote:I will second use of the ring terminal but use Dielectric grease and a washer between the wood and light.
