smaller 12 volt batteries ELB 1250A
Postby Ron Dickey » Sat Jan 19, 2019 12:17 pm
i found these at Home Depot used for emergency lighting battteries they are small and I am thinking of using one for left side and one for right and 1 for Galley, Recharging then thru one place.
they are small light and do not take up much space and do not cost much about $30,
Any thoughts on these??
Ron
121377......134179
Ron Dickey
Images: 711
Re: smaller 12 volt batteries ELB 1250A
Postby GuitarPhotog » Sat Jan 19, 2019 1:05 pm
Looks like those are 5 aH batteries. Exactly what do you plan to run off those? What do you plan to use to charge them?
I would expect you can run a couple of small LED lamps or a computer fan for an hour or two before you need to recharge. You can probably charge you iPad once or your iPhone twice.
You don't want to run those down below 50% before recharging or you will permanently damage the battery.
<Chas>
:beer:
GuitarPhotog
Images: 55
Postby GTS225 » Sat Jan 19, 2019 5:14 pm
Yes, Ron, you're right. They're small, light weight, and relatively low cost.
BUT; They are engineered for commercial/industrial emergency lighting, for when the power goes out in an industrial environment. They are supposed to power two, low-output lamps for about 6 hours. We have to replace them yearly where I work, and sometimes more often, as they are not very robust. Will they fulfill your small lighting needs? Only you can determine that. I suggest you'd be better off with a low-cost, Wal-Mart, lead-acid lawn tractor battery. At least that way, you can use a conventional charger to bring them back up to par, if needed.
Roger
GTS225
Postby Ron Dickey » Sat Jan 19, 2019 8:58 pm
LED inside light, under body night lite LED, computer fans, Galley lights
I think that maybe I will use for Fans and a cell recharge station,
battery tender, I am still learning about solar and have a source for that,
I am an experimenter and might see what I can do with wind energy too.
Ron
121377......134179
Ron Dickey
Images: 711
Postby Ron Dickey » Sat Jan 19, 2019 9:00 pm
GTS225 wrote: I suggest you'd be better off with a low-cost, Wal-Mart, lead-acid lawn tractor battery. At least that way, you can use a conventional charger to bring them back up to par, if needed.
Roger
I will check into that.
my build is a little heavy and may use it as a counter weight too.
121377......134179
Ron Dickey
Images: 711
Postby KTM_Guy » Sat Jan 19, 2019 11:06 pm
What is your amp use in 24 hours? that will tell you how long they will last. For me I'm planing on 15AH per 24 hours. I think that is on the low to average side of use. You would have 15 amp hours total, and you don't want to go less than 50% discharge so that is 7.5 AH of usable power. That is not a lot. Sure even a small solar setup would recharge the quick but if you had a cloudy day or two you are with out power.
Maybe look at the 35 AH wheel chair batteries if you want a small battery.
Todd
KTM_Guy
Images: 193
Postby Graniterich » Sun Jan 20, 2019 1:46 pm
KTM_Guy wrote:What is your amp use in 24 hours? that will tell you how long they will last. For me I'm planing on 15AH per 24 hours. I think that is on the low to average side of use. You would have 15 amp hours total, and you don't want to go less than 50% discharge so that is 7.5 AH of usable power. That is not a lot. Sure even a small solar setup would recharge the quick but if you had a cloudy day or two you are with out power.
Todd
35 amp 12 sealed battery is about $65. even led lights can add up to amps per hour!
Sent from my RCT6303W87M7 using Tapatalk
Graniterich
Postby GuitarPhotog » Sun Jan 20, 2019 11:35 pm
[quote="Graniterich"35 amp 12 sealed battery is about $65. even led lights can add up to amps per hour!
Sent from my RCT6303W87M7 using Tapatalk[/quote]
For certain. I use two LED strip lights, one in the galley and one in the cabin. They use 3A each (36W). Doesn't sound like a lot, but if you are camping for several days without hooking up, and the sun isn't shining, as is often the case up here in the PNW, it's pretty easy to run a battery down.
Build in more battery capacity than you think you need. You'll need it sometime.
<Chas>
:beer:
GuitarPhotog
Images: 55
Postby Ron Dickey » Mon Jan 21, 2019 9:31 pm
The more the merrier sounds good to me.
121377......134179
Ron Dickey
Images: 711
