by working on it » Tue Jul 30, 2019 8:40 pm
* If you're still worried about outgassing, then just install one of your computer case fans to expel any possible outgassing from the trailer, and leave it running 24/7/365. A normal 80mm case fan will last for around 30000 hours (or 3.425 years) while only drawing 1-1.2 amp-hours a day (negligible, especially if set to automatically charge).
* I have done so before, running them fulltime for six months in my garaged trailer, after I first built it, using two hi-static pressure 120mm fans, while the battery maintainer hummed away all winter (to keep the interior from getting stagnant)... with no ill effects to fans nor battery & charger. It was not really needed, because I haven't needed to repeat that, since there's enough airflow from convection in my steel garage (basically open at the top and around the sides) to keep the interior fresh enough (at least 'til I prep for the next trip). But it shows that the case fans can be used for low amperage, constant ventilation, if so desired.
* Another thing.... My HHR Panel has a lead-acid battery under the rear floor cover, and has a tube directed from it thru the spare tire well to the outside, to expel any outgassed products. However, that tube broke off, and I didn't replace it for ten years, most of which time I slept back there during ice-storm events when I couldn't commute back home. I also kept it charging while I was in it at night, with my head just above the battery cover panel. I never could smell any outgassing, nor was there ever any sign of corrosion. After I retired, and never had to sleepover in the Panel again, I finally replaced the first battery, after 10.5 years of service, and put another outgas tube there (finally).
* By the way, I always used a Battery Tender, or Battery Minder when my Panel, or any of my trucks were at home (or parked overnight in the company garage). That's why my batteries last for 10-12 years! My Optima Yellowtop in my TTT is only 7 years old, so it has a way to go, still.
2013 HHRv "squareback/squaredrop", rugged, 4x8 TTT, 2225 lbs- *3500 lb Dexter EZ-Lube braked axle, 3000 lb.springs, active-progressive bumpstop suspension
- *27 x 8.5-14LT AT tires (x 3) *Weight Distribution system for single-beam tongue
- *100% LED's & GFCI outlets, 3x fans, AM/FM/CD/Aux. *A/C & heat, Optima AGM, inverter & charger(s)
- *extended-run, on-board, 2500w generator *Coleman dual-fuel stove & lantern, Ikea grill, vintage skillet
- *zinc/stainless front & side racks *98"L x 6" diameter rod & reel carrier tube on roof
