First you need to list your loads both 12 and 120 volt.
You 120 v can be simple or hard, most teardrop trailers dont need anything beyond very simple.
12 volt loads can also be very simple. Mine is but I went stupid on a few things. Read my over complicated electrical system a few threads down.
12 and 120 are seperate, unless you buy a very expensive panel. For 12 volt just buy a simple blue sea fuse box, they are cheap.
You said inverter, are you going to have a shore power plug as well or just the inverter? If doing both you need a transfer switch. What you need to watch is to make sure your shore power charger is not connected to the output of the inverter, other wise power just goes in a circle. So for 120 bring in power, hit the shore charger, then the transfer switch, then the plugs inside/outside the trailer.Other side of the transfer switch goes to the inverter, so when its on shore power the plugs are feed from shore power, when its on inverter plugs are fed from the inverter.
Here is a simple switch to use for the transfer switch. It can handle 20 amps at 120 volts
https://www.amazon.com/gp/product/B001P ... UTF8&psc=1now 12 volt, you go from the battery to the main fuse block with some sort of disconnect, I used anderson plugs. From the main fuse block you go to the inverter, then preferably another fuse to the 12 volt fuse block. Then your loads come from there to what ever you need, be it switches for water pumps, fans light etc. I put in a master light switch, that then runs to switches for interior, ext, litcken light etc. I did that so I have one switch that kills all the lights when its not being used, I did that so I am less likely to leave a light on accidently. I did the same thing for my fans.
