by saltydawg » Tue Jan 19, 2021 8:29 am
Ok there is two types of breakers, thermal and thermal magnetic.
Thermal is designed for when there is an overload they heat up until a small bi metallic strip causes it to trip. The nice thing is they can be very accurate, ie with proper design and build a 20 amp can be made to trip at 22 amps. It takes a few mins to heat up to that point before it trips thou. Yes ambient temps can mess with it a little, ie take longer to heat, or maybe allow then to draw 24 amps if they where in a very cold draft. The problem is a short has to heat it up before it can trip, so a short of say 80 amps might take 10 seconds to heat it up to trip, or 30 amps might take 5 mins. 30 amps really is not a short, shorts can carry 200 amps for a very short period.
Thermal magnetic have the above plus a electromagnet in them that can sense and trip a high current short instantly. So say over 40 amps the 20 amp would be instant, not take 2 or 3 mins.
So its a compromise to just go thermal, but in something with very limited electrical ie a teardrop, backed up with a gfi for ground short protections is about as safe as it can be. If you get a short to ground the gfi will trip, if you get a small over load the thermal will trip in a few mins, ideally before any damage is done. And most small overloads wont hurt a thing, unless its for hours or days or maybe not at all.
Some people will remember federal pacific breakers, when they came out with their skinny breakers they where only a thermal breaker and poorly designed at that. So they allowed circuits in house to draw 40 for mins before they would trip, or maybe 30 and never trip when the breaker was rated at 15 amps. This damaged the old wiring in houses that was in rough shape already and did cause houses to burn down.
Dont bother with arc fault, its not needed. In a house its fine, where it can detect a loose connection before it starts a fire, but in a teardrop its just wasted money.
Scott
Lost in Maryland
