Sparksalot wrote:Yes, on the fuse at the battery. That’s an absolute must have. The usb doesn’t really need a switch, unless you just want to. Both of your lights will be controlled by the one switch.
Fir Rose I have two cabin and two porch lights. Each one has a switch for flexibility.
trailzy wrote:Sparksalot wrote:Yes, on the fuse at the battery. That’s an absolute must have. The usb doesn’t really need a switch, unless you just want to. Both of your lights will be controlled by the one switch.
I've been wondering if I put a fuse between the battery and the connect plug, do I need that junction FuseBUS?
Thanks
