Waiting for top balancing … … … it is up to 3.31 volts, which is the same place it was yesterday … … …
I created a “model” of the back wall of the compartment where the battery will live and sketched the components on it.
I’ve got the main off switch, a big fuse, and a breaker coming off the positive, and the shunt on the negative side. The inverter is the big rectangle below that stuff.
I need to mount the BMS to the front of the box, but those rods are in the way and the BMS has no screw holes in it. I think I remember people using VHB tape to stick BMS’s to battery boxes, but not to wood. I’ll have to see what I can come up with. I have a little of the white ABS plastic sheet left that I could mount there using screws, then VHB tape the BMS to the plastic surface.
