Grounding MPPT Victron Solar Controller
Anything electric, AC or DC
Postby Capebuild » Sun Aug 29, 2021 7:10 pm
I just installed in place a 100/30 Victron Solar Controller. I'm not sure where the ground screw should be connected to. I suppose one place would be the chassis frame. But I'm wondering if it could be connected to a negative terminal on the Blue Seas bus bar I'm using. In my overall set up there is no grounding at all to the chassis frame and the chassis frame is not being used for any negative wiring returns. Any thoughts about where to wire that grounding screw on the solar controller?
Thanks.
John
Capebuild
Images: 129
Re: Grounding MPPT Victron Solar Controller
Postby John61CT » Sun Aug 29, 2021 7:33 pm
What does the installation documentation say?
John61CT
Postby saltydawg » Sun Aug 29, 2021 9:14 pm
Typically that ground screw is used in a residential system and is an earth ground. So my opinion is dont worry about, or just bond it to the frame if it makes you feel better.
I looked at the manual there is no mention of it, so thats a dead end. Also their customer service is ok, and some times from what I have heard poor.
Scott
Lost in Maryland
saltydawg
Postby John61CT » Sun Aug 29, 2021 9:55 pm
Victron's business model is
buy from good quality certified dealers
they are your frontline support
Victron supports them if anything needs escalating
5-year warranty on everything worldwide
Their online support forums are great
their top level engineers do regularly contribute there.
Top quality and value gear.
Alan at Bay Marine is my reco, buy direct rather than his eBay or Amazon shops.
John61CT
Postby John61CT » Sun Aug 29, 2021 10:02 pm
> Chassis grounding
> A separate ground path for the chassis ground is permitted because the chassis is isolated from the positive and the negative terminals
So, not mandatory to ground that chassis point
John61CT
Return to Electrical Secrets
