Water pump??
Water pump??
Postby John T3 » Sun Mar 26, 2006 11:17 pm
Originally I had designed my tear to use a gravity fed system, but after test fitting it I decided to relocate the water tank to the galley floor under the faucet.
Now I'm in a bit of sticker shock :shock: surfing the net for water pumps. The cheapest thing I see runs over fifty bucks (Shurflo). Well, I'll bite the bullet if I need to, but has anyone seen or is using something else?
John T3
Images: 23
A way cheaper pump
Postby Guy » Sun Mar 26, 2006 11:22 pm
Dear John,
The are many pumps cheaper than that. There was a wholethread that I think Madjack contributed to regarding pumps with a faucet and a switch for under 25 dollars. Hold on I will try to locate it for you.
Success using google site search http://www.tnttt.com/viewtopic.php?t=7513&start=0&postdays=0&postorder=asc&highlight=
Regards,
Guy
Guy
Images: 44
Postby GeorgeTelford » Mon Mar 27, 2006 4:18 am
Hi John
Of course you realise that you still do not have to have an electric pump?, there are plenty of hand pumps out there.
GeorgeTelford
Re: Water pump??
Postby Steve_Cox » Mon Mar 27, 2006 8:17 am
John T3 wrote:Originally I had designed my tear to use a gravity fed system, but after test fitting it I decided to relocate the water tank to the galley floor under the faucet.
John,
I lived on a boat with a hand pump, It works good but I really love my 12Volt pump. Used it the first time last weekend.4 days camping, it was great, good water flow at the touch of a button. This is the best value I have found in a pump too.
Pump link
Steve_Cox
Images: 196
Postby GeorgeTelford » Mon Mar 27, 2006 11:24 am
Wow $25 for both thats a fantastic price, is that really Jabsco or just "replacement for" Jabsco?
GeorgeTelford
A replacement
Postby Guy » Mon Mar 27, 2006 1:09 pm
Dear George,
It is a replacement.
Regards,
Guy
Guy
Images: 44
Postby John T3 » Thu Mar 30, 2006 1:27 pm
:) Thanks for the advice all! I bit the bullet and spent 45$ at Camping World for one. Self priming, no switch, minimum hassle. I was tempted to get the hand pump, but I already have the faucet. Then, after all the dough I've already put into the project I didn't need to listen to the spousal unit ask, "I have to what to get water?" :roll:
John T3
Images: 23
