kuffelcreek wrote: There are too many nuances about high-voltage wiring in a metal-clad trailer (which is insulated from the ground) that can be fatal or cause a quick fire. Things you may get away with in the house or garage can kill you on a trailer.
You now have a floating ground on the frame. It will take the path of least resistanse to ground, And that would be YOU If you are grounded and touch the frame.
GeorgeTelford wrote:What bothers me is that people keep reccomending stuff and they have no idea at all of the dangers they are passing on to other people.
cracker39 wrote:Gadgetman, The posts about the electrical matters made me plenty nervous lots of times. I finally asked many questions and digested the answers and think I'm OK.
As to why it popped at the campground and not at home? Could this be why? If the neutral and ground were bonded (until the neighbor fixed it), and there was no GFCI at home (none at my house anyway), wouldn't it work ok at home since the main panel on the house may have them bonded as well, and pop if the campground had the GFCI in their box? Seems likely to me, but then, I'm an amateur re electricity.
GeorgeTelford wrote:Artificer
Even if the campground wiring is reversed it would make not one iota of difference to a GFCI tripping, reverse polarity can cause certain problems but tripping GFCI's is NOT one of them.
Earth neutral bonding within the tear may have been (part of) the problem. for safety reasons we now need to know whethor Gadget as a GFCI at home, reading what Gadget as written so far I think he has, in which case further investigation is required.
Computer power supplies do not have earth bonded to neutral that is a complete crock. would be against code or regs in even the worst of third world countries.
