Carrying Fresh Eggs
Carrying Fresh Eggs
Postby S. Heisley » Fri Aug 11, 2017 1:14 pm
We like to cook fresh eggs for breakfast; and, if we are going to be out for a while, that could mean carrying quite a few eggs.
Most the time, the eggs are used for scrambled eggs or pancakes, etc, which means they don't have to be whole. I take as many as I need plus a few more and break them into a bottle or jar and transport them that way. The jar stands up in the cooler and there's no worry about broken, spilled eggs. To scramble, you just shake the jar and then pour out what you need. No need for a bowl and fork to scramble them. A quarter cup is about the equivalent of one large egg. If we think we'll need some whole eggs, for variety or whatever, we can still take the camp egg carrier that you see below, on the right. That 64 oz Ocean Spray bottle has two dozen eggs that were funneled into it and could still hold another dozen. The 1/4 cup measure that we have happens to fit right over the cap.
Images: 490
Re: Carrying Fresh Eggs
Postby QueticoBill » Fri Aug 11, 2017 4:03 pm
I take fresh eggs camping - in backpack or portage pack. I think I had one crack in many dozen over many years.
No doubt there will be some disagreements but fresh eggs - never washed or chilled - are easier since they definitely don't need refrigeration, but I do carry grocery store eggs for a week or two and don't worry. Mediums seem tougher and thicker shelled than large. I've had it with the plastic carriers - one trip and several cracked - want one anyone? The cardboard/paperboard cartons are better than foam. Last, I wrap a double layer of bubble wrap - small bubble - around (and secure with a bungey dealy bob - but a rubber band will work.) Very successful. I know another couple who swear by taping it to the underside of a their canoe seat - so I imagine you could do similar in a trailer.
Nothing quite like fried eggs and bacon around a campfire with some good cowboy coffee.
QB
QueticoBill
Images: 22
Postby tony.latham » Fri Aug 11, 2017 5:19 pm
One little tip on using eggs for baking: Use a can of 7-Up instead of the eggs. Just pour enough into your mix to give your batter the right consistency. Works great.
Tony :thumbsup:
Postby working on it » Fri Aug 11, 2017 5:41 pm
S. Heisley wrote:We like to cook fresh eggs for breakfast
QueticoBill wrote:Nothing quite like fried eggs and bacon around a campfire with some good cowboy coffee.
  • As Anthony Bourdain once said on his second TV series, No Reservations, "I am an egg slut". I am one, too. I'll eat eggs and bacon anytime, or either, with anything. Trouble with eggs is to keep them fresh; I've had problems keeping usually refrigerated perishable foods cold enough, over a long weekend camping, so I first resorted to liquid "Egg Beaters", which I would partially freeze (which would aid longevity later on), but would become just on the verge of getting too warm, on the third day forward. That might work better now that I'll be using my home-built/modified "supercooler", but maybe not. I've been considering using dehydrated eggs, such as
    dried scrambled eggs; no refrigeration needed.PNG (236.25 KiB) Viewed 860 times
    if its eggs, I'll use it in any form...lots of it to use, too
  • I've never tasted powdered eggs, but, as my wife can attest, when it comes to eggs, I'll just take them any way I can get them. This can should last me a week or two, in between campouts!
2013 HHRv a "squareback/squaredrop" 4x8 TTT,
semi-offroad?, at barely under 2000 lbs travel weight
  • 3500 lb Dexter EZ-Lube axle, w/brakes
  • 27x8.5-14LT all-terrain tires (x 3)
  • LED lighting, triple fans. Pioneer stereo
  • A/C & heat, Optima AGM, inverter & charger(s)
  • extended-run, on-board, 2500w generator
  • Coleman dual-fuel stove & lantern, Ikea grill
  • zinc/stainless steel front racks
153929148599153928155112
working on it
Images: 440
Postby S. Heisley » Fri Aug 11, 2017 6:02 pm
QueticoBill wrote: .... The cardboard/paperboard cartons are better than foam. Last, I wrap a double layer of bubble wrap - small bubble - around (and secure with a bungey dealy bob - but a rubber band will work.) Very successful. I know another couple who swear by taping it to the underside of a their canoe seat - so I imagine you could do similar in a trailer.
The bubble wrap idea is a good one! :thumbsup:
Images: 490
Postby slowcowboy » Fri Aug 11, 2017 7:35 pm
Yellow egg box for slow like the bottle idea to...
Sent from my SAMSUNG-SM-J320A using Tapatalk
Plans. there was supposed to be plans to be followed when I built this thing. Opps! AH, gee, tum,tee tum. I think I forgot about the plans 2 years ago. ------Tow vehicles, 1995 ford explore, 1994 ford ranger, 1993 ford F-150, 2009 4x9 Off road teardrop, on harbor freight greatly modified frame.
slowcowboy
7000 Club
7000 Club
Images: 166
Postby kokomoto » Fri Aug 11, 2017 8:58 pm
Ahhhh, powdered eggs. Those bring back memories of my days at sea in the Navy. I swore I would never eat them again, but maybe they've gotten better over the years. If not, I could always cover them with a some Crystal Louisiana hot sauce :thinking:
I do like the eggs in a jug. But the fresh, unrefridgerated eggs sound the most tasty. :thumbsup:
kokomoto
Postby kokomoto » Fri Aug 11, 2017 9:01 pm
tony.latham wrote:One little tip on using eggs for baking: Use a can of 7-Up instead of the eggs. Just pour enough into your mix to give your batter the right consistency. Works great.
Tony :thumbsup:
Whooda thunk? :roll: 7-Up makes good eggs, but eggs don't make good 7-Up.
kokomoto
Postby AzAv8r » Fri Aug 11, 2017 9:55 pm
Many years ago, at the "Visiting Nurses Association Book Sale" (an annual event where used books are sold for fund-raising) I bought a book on cruising (as in long-term sailing). I remember reading fresh eggs would last several weeks unrefrigerated - just invert them fairly often. I don't recall the definition of "often", but it was probably every few days.
But we still refrigerate our eggs when camping. We have several sizes of plastic egg carriers. The paper ones probably provide better cushioning, but they absorb water...
AzAv8r
Images: 6
Postby capnTelescope » Tue Sep 26, 2017 8:18 am
I traveled a lot of rough roads in northern Canada and Alaska this summer. Bought 'em by the half-dozen whenever possible (impossible in Alaska, where eggs come from Washington state). Kept the carton in a gallon plastic zipper bag for obvious reasons. You will need to cut down the dozens to fit in the bag. There was less breakage from the half-dozen cartons than the whole dozens.
Brad
My Build
capnTelescope
Images: 364
Postby S. Heisley » Tue Sep 26, 2017 9:31 pm
Another thing that I like about carrying eggs in a bottle or jar is that you can use less egg yolks. I am now adding one egg white for every whole egg in my bottle, to help fight excess cholesterol. ...Don't even notice the difference. :)
Images: 490
Return to Camping Secrets
