combination Propane and charcoal grill
Postby tbeau » Wed May 07, 2008 10:08 pm
Does any one know if they make a portable grill that has both propane and charcoal? and if so how well does it work. I have seen a few larger ones listed.
tbeau
Images: 46
Postby excalibur5 » Fri May 09, 2008 5:50 pm
I have never found a portable charcoal/gas combo grill. If they did make one, I wouldn't buy it--the air flow requirements are too different for the types of fuel. Gas grills require a lot of air flow to burn, but charcoal grills should be nearly airtight when closed up in order to control the heat level. (too hot=close up the vents a bit and snuff down the fire).
IMHO, get a Weber Smokey Joe, it will do everything, and are a very well built little grill..
If you want a non-portable grill for home use, however, this one is pretty awesome.. Just add the side fire box, and you have a charcoal grill, a texas style offset smoker, and a gas grill for flipping burgers all in one unit.. I have the smoker portion with side fire box, and love it.
http://www.chargriller.com/duogrill.html
excalibur5
Postby caseydog » Fri May 09, 2008 6:30 pm
I agree on the Smokey Joe. My TD grill is a Smokey Joe Gold, which is a little different. The Gold model travels better, with no holes in the bottom and a locking top.
http://www.weber.com/grills/?glid=7&mid=31
Get this, and a few of those small Kingsford MatchLight bags, and you have an easy fire for cooking on the road.
CD
My build journal is HERE
caseydog
Images: 515
Return to Camping Secrets
