Step 4: Cut out the walls
Here is a generic building plan for a teardrop designed by the members of T&TTT.
Postby mikeschn » Tue Apr 26, 2005 12:46 pm
(Revised 10-May-2005 to allow for sidewalls to cover trailer frame)
(Revised 13-Sep-2005 to cut walls separately)
The walls are 4’x8’x ¾” Birch plywood. The good surface will be the inside of the teardrop.
Layout the position of the bulkheads and cabinets on both inside walls, using a 4’ t-square. Refer to the drawing below…
Next, layout the positions of the joists.
Then place the first sheet of plywood, good side down, and layout the Benroy profile using 2 homemade beam compasses. A beam compass is just a length of wood with a nail in one end, and a hole for a pencil in the other end. The short compass will have a 19” radius, and the long compass will have a 48” radius. At this time you’ll also want to layout the door, and the window.
Using a Jigsaw, cut out the profile and the doors Use a belt sander to sand the profile and the door openings smooth.
Now let’s layout the other wall. Remove the first wall. Set the second piece of plywood good face down on the saw bench. Layout the door and window. Now place the first wall on top of the plywood, good side up. Using this as a template to trace the wall profile on the plywood. Remove the template and cut the profile and the door opening. Use a belt sander to sand the profile and door openings smooth
Tip: Initially the plan was to cut both pieces of plywood at the same time. But when I tried that using ¾” plywood, the blade angled, making the underneath piece quite a bit smaller than the top piece. So even though it sounds like more work, you’ll end up with a better quality teardrop if you cut each piece separately!
Drill and countersink holes xxx” from the bottom edge of the wall, every 8”. (The countersink should be on the outside of the wall.) The xxx” should be equal to the height of the trailer side rail, plus 3/8”.
Drill and countersink a hole at one of the spar locations towards the center of the wall.. Drill and countersink a hole at the final spar location where the hatch will start. These will be used for temporary spars in the next step.
Images: 479
Postby type82e » Tue Apr 26, 2005 7:55 pm
great info! photos would be even better
what is the front radius?
marcel
type82e
Postby mikeschn » Tue Apr 26, 2005 8:20 pm
I'll definitely have a drawing for this post... The front radius will be equal to the back radius... it appears to be about 16", but I'll confirm that for you once I start modeling it.
Here's a rough sketch of a Benroy profile... I'll be doing a simplified version of that for the generic plans.
It'll end up looking very similar to this...
Images: 479
Postby SteveH » Tue Apr 26, 2005 8:55 pm
Mike,
You just MUST keep the back end eliptical. It just won't look right if it's a simple radius. It won't be a Benroy then, it would be a Rimple.
Just my "opinion" of course.
SteveH
SteveH
Images: 42
Postby mikeschn » Tue Apr 26, 2005 9:01 pm
We could always call it the simplified Benroy... or is that rimplified Benroy? Andrew, what do you think? Should it be ellipitical or what?
Images: 479
Postby Chip » Wed Apr 27, 2005 4:45 am
Heck since its a variation of the original,, Go for the glory and call it a Mike-L-Roy ! Sort of has a nice ring to it too,, dont ya think,,
chip
54"x9'4" tear
4'x8' tear
Chip
Images: 49
Postby angib » Wed Apr 27, 2005 5:59 am
mikeschn wrote:Andrew, what do you think? Should it be ellipitical or what?
I'd say steer clear of ellipses - I like the look but they do seem to scare people off and this is meant to be an easy trailer.
Andrew
angib
5000 Club
5000 Club
Images: 231
Postby SteveH » Wed Apr 27, 2005 7:20 am
Andrew
Andrew,
Using your string and pencil method, drawing the elipse when I built my trailer was the easiest thing I did!
SteveH
SteveH
Images: 42
Postby JunkMan » Wed Apr 27, 2005 9:03 am
SteveH wrote: Andrew,
Steve I agree, but I did have a little trouble figuring out where to put the loci (locuses?). I really think the ellipse adds to the look, and if the loci are given, it shouldn't be too hard for a beginner to do.
Jeff & Odie
Black Hills of South Dakota
JunkMan
Images: 50
Postby mikeschn » Tue Sep 13, 2005 11:35 am
Step 4 revised 13-Sep-2005 to cut walls separately.
Images: 479
Postby mikeschn » Sun Oct 09, 2005 5:45 am
type82e wrote:great info! photos would be even better
marcel
If anyone is still looking for drawings for this step... I've posted 3!
Images: 479
Postby dacrazyrn » Tue Oct 18, 2005 12:18 pm
dacrazyrn
Images: 74
Return to Generic Building Plans
