Insulation query
Here is a generic building plan for a teardrop designed by the members of T&TTT.
Postby DasBaldGuy » Tue Sep 08, 2009 10:10 pm
Arne wrote:R value of 3/4 ply is .91 +/-....
the lowest I could find for 3/4 foam was R = 2.6
We are talking about the 3/4 inch "blue" styrofoam 4x8 sheets available at bigbox home improvement store, correct?
DasBaldGuy
Postby Arne » Wed Sep 09, 2009 8:29 am
I used pink, as that is what h/d had available.. I think the white with foil is higher..
R-Values Per Inch For Common Insulating Materials*
Insulating Material Avg. R-Value Per Inch
Batts or Blankets
* Mineral fiber (rock, slag or glass)
3.25
Loose Fill
2.2
* Cellulose (milled paper and wood pulp)
3.4
* Vermiculite, exfoliated
2.13
* Perlite, expanded
2.7
Rigid Board and Slabs
* Expanded polystyrene, extruded (cut-cell surface) and molded bead-type
4.0
* Expanded polystyrene, extruded (smooth-cell surface)
5.0
* Expanded polyurethane, refrigerant 31 exp.
6.25
* Polyisocyanurate
7.04
Building Board Sheathing, regular density 2.64
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby eight433 » Wed Jan 27, 2010 1:20 pm
I used 3/4 plywood, AND 3/4 pink insulation on the walls. 2x2 rafters for the ceiling, with 1 1/2 white Styrofoam insulation in the roof, AND a fantastic fan with two windows. I had it outside the other night with a 10 dollar coil/fan heater and it would keep it HOT inside of that little camper. It was 18 degrees and windy that night. It got even better after I put weatherstrip around the doors.
IMO, you can never over insulate. I might even insulate my cabinets, as that is the only place I feel cold air yet.
eight433
Images: 31
Re: Insulation query
Postby stmaryscowboy » Mon Jul 18, 2016 9:34 pm
Has anybody used the original 2X2 wall construction and used the spray in polyurethane in the walls, ceiling and in the floor? If so does it help with structural rigidity? I my way of thinking it would help in maintaining the temperature, humidity, noise and help make the frame more rigid. I would appreciate any input.
stmaryscowboy
Re:
Postby felixx » Mon Jul 18, 2016 11:45 pm
pieface wrote:Hi
There is a guy in Bury who is selling tears on e bay http://cgi.ebay.co.uk/american-teardrop ... dZViewItem
if you look at his photos he appears to have used 3/4 ply and cut it out to lighten it and then insulated the voids. I'm not sure if I would want to go that route myself but every one to their own. :thinking:
I think that camping in our weather conditions would need insulation and good ventilation. :lol: Having said that I have been thinking about 3/4 ply and covering the interior with that thin cord carpet type material that they use on the inside of our buses.
pieface 8)
I did that.. cut voids and insulated em..
works well
felixx
Images: 22
Return to Generic Building Plans
