Step 8: Glue up the walls and the cabinets
Here is a generic building plan for a teardrop designed by the members of T&TTT.
Postby mikeschn » Tue May 10, 2005 12:01 pm
This is a major step. Make sure you have all your help lined up, and all your pieces handy.
1- Remove temporary spar
2- Remove the first wall
3- Put polyurethane glue on the wall where it will touch the floor
and the floor framing
4- Put wood glue on the edges of the cabinet assembly
5- Reinstall the wall, and put in all the floor screws
6- Put in all the cabinet screws
7- Repeat on the other side
8- Put your temporary spar back on
9- Take a break, you’ve earned it!
Images: 479
Postby dacrazyrn » Tue Oct 18, 2005 12:20 pm
dacrazyrn
Images: 74
Return to Generic Building Plans
