TT Plan by Jofa
Here is a generic building plan for a teardrop designed by the members of T&TTT.
TT Plan by Jofa
Postby jofa » Wed Oct 05, 2011 6:00 pm
this is my plan. :) if you have any suggestion, i am listening.
TT is little higher than usual, I want to be able to sit on the "sofa". 8)
not sure yet but will probably go with two door verison. :thinking:
here is my electricity plan:
http://www.mediafire.com/?bdp594sj489bjfj
jofa
Postby mikeschn » Fri Oct 07, 2011 6:15 pm
I have to say, that's a good plan.
In my Giant Teardrop I have no place to sit and relax.
Images: 479
Postby crttaz » Sat Oct 08, 2011 2:55 am
I'd be happy with that, but would have more drop storage. A space under the sofa for rarely used back up parts.
I'm thinking of attaching the shell to the trailer via the drop boxes.
crttaz
Postby jofa » Sat Oct 08, 2011 4:51 pm
being able to sit in the TT is very important to me. That is what determinate angle of the front wall and hight of TT.
drop box that you see on my sketch is not realy storage box but something that give you right angle for your legs when you sit on "sofa".
I will add two more boxes for storage in front (under the "sofa").
Table on the side of the TT is actually box cover. There will also be one more table inside of TT. ...if you're caught by bad weather, you can eat inside. I will also make tent to cover galley so you can cook when it is raining.
All ideas are welcome!!!
Thank you.
jofa
Postby crttaz » Mon Oct 10, 2011 1:14 am
but the drop box could be used for storage while in transport, empty out on arrival, now you have a decent sofa.
Big enough for a 10x10 canopy and tie downs?
crttaz
Postby jofa » Mon Oct 10, 2011 4:37 am
crttaz wrote:but the drop box could be used for storage while in transport, empty out on arrival, now you have a decent sofa.
You are absolutely right
box is 100x60x20 cm
jofa
Postby crttaz » Mon Oct 10, 2011 4:09 pm
getting the dang 10x10 back into it's storage bag is a PITA. Anymore after the races we just break it down and use bungee balls to tie it in a bundle. Even if you are careful the zipper on the bag still gets ripped.
crttaz
Re: TT Plan by Jofa
Postby 007BigBig » Sun Jan 13, 2013 11:13 am
Jofa, I really like the plan! Are you willing to share the sketchup file? I'm "building" a Grumman 2 in sketchup now. Just in research phase right now - no physical building yet.
Eric
007BigBig
Return to Generic Building Plans
