4" square tubing bumper
Postby wilhansen » Mon Jul 24, 2017 12:43 pm
Hey folks!
I finished renovating a 1973 Roadrunner trailer, and one of the only things left to do is to replace the rear bumper on the trailer. It's rusted out and nearly falling off - so it is a bit liability right now. 4" square, but I'm not sure what gauge the steel typically is on these bumpers. I want it to be strong enough to carry camp wood and a bike rack, but obviously not thicker than it needs to be!
I've found steel tubing companies online, where I can order the length that I need (7'6"), in different gauges. I'd rather not have a local RV company do it, I know they'll charge twice as much for the tubing and $$$$$$$$ in labor. What could be a couple hundred bucks for me to do myself, would easily turn into $1,000 for them to do it.
Any ideas?
wilhansen
Re: 4" square tubing bumper
Postby MtnDon » Mon Jul 24, 2017 1:03 pm
RV bumpers are normally 4 x 4, 14 gauge steel; 0.080". That allows the use of the plugin rubber ends and is strong enough for carrying bikes / wood. Do you have a metalsupermarket near you?
MtnDon
Images: 24
Postby greygoos » Mon Jul 24, 2017 1:24 pm
4 X 4 Vinyl fence post available at HD and Lowes. The rubber ends fit on them. Fill it with expanding foam. Drill a few holes and fasten it to the trailer with carriage bolts.
greygoos
Postby wilhansen » Wed Jul 26, 2017 2:02 pm
Checked with Metal Supermarket - they only make the 4" square with .12" thickness. Which is fine with me, but I'm worried my drain tube and caps won't fit with the smaller inside diameter?
wilhansen
Postby Dale M. » Thu Jul 27, 2017 7:56 am
Try measuring you existing bumper for thickness before making any decision...
If existing bumper is .080 and new material is .120, you are only talking about a inside dimension that is .080 smaller...
It would be 3.840 vs 3.760... The difference is only .080 or less then 3/32 inch (actually 2/25)..
Dale
Dale M.
Images: 18
Postby wilhansen » Thu Jul 27, 2017 3:26 pm
I would measure, but it's so rusted out that the thickness is minimal...
I called several companies and they all mentioned that .120 was pretty standard these days and that nobody in town here carries a .08.
I think it will work out fine. :)
wilhansen
Users browsing this forum: No registered users and 26 guests
