tire size 155/80R13 on NT trailers
Postby sned » Tue Sep 04, 2018 8:56 pm
Anyone running 155/80R13 on their NT trailers? Want to verify there are no fit issues.
It's just under 1 inch wider so it should fit with.
Is there a better place to purchase wheels and tires from then recstuff.com?
sned
Re: tire size 155/80R13 on NT trailers
Postby sned » Sun Sep 09, 2018 11:58 am
if your not running 155/80R13 what 13" tire are you running?
sned
Postby Woodbutcher » Sun Sep 09, 2018 4:12 pm
I am running 14" wheels that are 5X4.5 bolt pattern. The important part is the back spacing, on your rims. Shoot for zero offset. You need to plan whether you are going to build over the frame, or sit on top. Over the frame will lesson the space between the tire and the frame. I have also used 1" wheel spacers to move the wheel out for more clearance. I have over 20K trouble free miles on the trailer with spaces.
Woodbutcher
