How fast can a NT 5x8 trailer go?
Postby Joe4Camping » Sat Nov 11, 2017 8:07 am
Hello,
Brand new member here, planning on building and crafting a TD. I've read countless posts here on TNTTT, and feel ready to take the plunge. First question: The NT 5x8 trailer seems to be a popular base to start with. I'm curious, how fast have other TD'ers been able to travel with these trailers? And, is there noticeable shimmy that needs to be overcome?
Many thanks!
Joe4Camping
Images: 88
Re: How fast can a NT 5x8 trailer go?
Postby Woodbutcher » Sat Nov 11, 2017 8:18 am
Mine has over 20K miles on it. Same axle hubs and bearings it came with. I did upgrade to larger tires. If there is a concern, it would be with the tires. But I know several people that have gone many miles with the stock tires. As for speed, I try and never go faster then 65-70 MPH. Not because it's a NT trailer, but just because I'm towing a trailer, any trailer.
Woodbutcher
Postby Joe4Camping » Sat Nov 11, 2017 4:54 pm
Perfect, thanks. I may upgrade to 14" tires, with appropriate wheel spacers (haven't decided on the width of the spacers yet, I'll figure that out once I get the trailer).
Joe4Camping
Images: 88
Postby Woodbutcher » Sat Nov 11, 2017 5:02 pm
I used 1" spacers with 15 X6 rims with zero backspacing. But I would build out and check the rims you use before ordering spacers to be sure. Good luck!
Woodbutcher
Postby rkanz » Sat Nov 11, 2017 10:17 pm
I built my TD on an aluminum NT trailer. I bought new 12" wheels with Kenda radial tires from E trailer. This summer I towed the trailer 2000 miles across Nevada and Utah at speeds of 65 to 70 mph. Tongue weight is about 10% depending on how I load the trailer. It towed perfect, the trailer is realatively light at around 600 pounds. I would not tow at those speeds with the stock tires.
rkanz
Postby swoody126 » Sun Nov 12, 2017 7:39 am
the REAL QUESTION is
¿CAN YOU STOP?
bearings and tires can be upgraded to components that will do the speed BUTT
¿CAN YOU STOP?
A major component to the answer to the OP's Q is
¿CAN YOU STOP?
AND
¿CAN YOU STOP SAFELY?
my F-350 CAN SAFELY STOP virtually any TD or TT
my Jeep ¿maybe ±?
it aint the trailer that necessarily governs how fast you can go
it is the ability of the TV to STOP THE COMBINATION SAFELY
just this old man's 2¢ worth
sw
swoody126
Postby dmdc411 » Sun Nov 12, 2017 9:48 am
I bought a northern tool 5x8 landscape trailer. After she was complete, I didn't like the 12" wheels. Borrowed a 13" tire & wheel from my buddies shop. No fit!! I figured at least a 1" spacer would be needed. I witnessed a buddy totalling his Roadrunner back in 1980 due to wheel spacers, and lousy wheels!. So they're not for me, even on a 1000lb trailer. I would weigh the thought of a wider axel to allow the use of bigger wheels. Or, like l decided. Buy good grade tires, use Timken bearings, good quality grease. I pull my TD at 75mph on freeways. Keep it loaded with no more than what is needed. Everything else in the truck!
Sent from my SAMSUNG-SM-G870A using Tapatalk
Forgot to say, I stayed with the 12" wheels, just getting ready to from 4.80 -12 to 5.30-12s. Higher load range. Tows like dream though. Nice and level.
dmdc411
Postby working on it » Sun Nov 12, 2017 12:05 pm
Joe4Camping wrote:Perfect, thanks. I may upgrade to 14" tires, with appropriate wheel spacers (haven't decided on the width of the spacers yet, I'll figure that out once I get the trailer).
  • My original axle was very small, with 8" wheels. I absolutely refused to consider using that size wheel, and momentarily considered getting 12" wheels (which were on sale at Northern Tool, at the time), but decided to go bigger, into familiar territory, by using automotive-sized wheels with bigger, cooler-running bearings. I've had many cars with tires in the 14"-16" size range, and never had any wheel bearing problems with any, so that was proof of the bigger wheel/bearing theory to me.
  • I was on a very limited build budget at the time, making me stay with the small axle, but I sourced big bearings/hubs (with five lugs, for automotive/trailer wheels) pretty cheaply thru a friend, and my eventual choice of using 14" wheels was for build economy, too. I did spend a large amount (comparatively) on a set of quality adapter/spacers to make the 14" wheels/tires fit, but I've used many spacers over the years, and these were better than any, so I had no qualms about using them.
  • I always planned on a braked axle upgrade, later, for when I could justify the expense vs just getting by, so I agree that braking is very important, and should be added to any trailer as soon as possible, though my TV truck didn't require that the trailer had any. Here's my comments concerning these subjects from an earlier thread, Trailer Selection Help http://www.tnttt.com/viewtopic.php?f=35&t=68873&hilit=adapters+wheel#p1209647:
    Tigris99 wrote:The trailer speed issue is a liability for the bearings because of the small tires. Repacking with good grease helps a lot. Better bearings with bigger tires goes a long way with that too...
    • If there's any question in your mind of having future problems using the stock HF axle/bearings/wheels/tires, especially trailering at high speeds (I tow at 75 mph), or going off-road, or building a trailer near or over the axle's rated capacity, then just go ahead and upgrade now, if your budget affords it. Retro-fitting later, as in my case, limits choices and is harder to do than at the early build stages. I knew I would need better running gear, eventually, but I piece-mealed the improvements over time, due to having a low-or-no budget situation, at the start. You have the opportunity to upgrade now, before problems arise later.
    • The "junk" trailer I started with had 8" wheels on a 1.25" square-tubed axle, of unknown weight capacity, so I put larger bearings and 5 on 4.5 hubs (replacing the 4 lug originals) so I could use 14" tires on it. I chose 14" tires because they are the same size that my wife's business trailer has (so I could get a free spare, to share), and a friend had two extra 14" tires on hand. There was no way I would've trusted my trailer build to using the smaller tires and bearings on highways, especially since I had burnt up one of the original bearings, just bringing the "junk" trailer back from a swap-meet 20 years before. I also had to use 1.25" wheel spacer/adapters to make the larger tires clear the frame.
    • I always intended to make my trailer a "heavy-duty" off-road type, just in case I or my wife would ever need it to go to out-of-the-way campsites, so larger tires were a better choice, though I wanted to eventually replace the light-duty axle before any excursion on rougher roads, in the future. As it turned out, I had the opportunity to upgrade my axle after a spring hanger tore loose, so I bought a 3500 lb Dexter (wider than the original, thus eliminating the spacers), adding brakes and better springs, and reinforced the frame at that time. Still on a limited budget, though I had improved the axle situation, I still used my aged and patched ST tires for two more years (they were at least 12 years old by then), before replacing them with good LT tires.
    • Now, after upgrading all the suspension and rolling stock, I have no worries travelling at high speeds, or over rough terrain. But, to do it again, I would've built it from the ground up, rather than correcting mistakes or bad choices, later on.
    • 86927 starting point; needs a lot of work, obviously
    • 86933 enlarged frame, same axle (with larger bearings/wheels)
    • 118140 original spindly axle (unknown capacity)
    • 119025 Dexter 3500 lb axle & better springs
173193172890148599
working on it
Images: 457
Postby Joe4Camping » Sun Nov 12, 2017 1:18 pm
All of this is fantastic advice, and MUCH appreciated. This is exactly why I joined TNTTT (and of course access to all the great Smilies).
My TV is a '08 Chevy Trailblazer 4.2L 4WD (towing capacity 5500#), so I think I will be able to tow & brake a foamie. :thumbsup:
Now, time to order that trailer and get crackin' ! :woohoo:
Joe4Camping
Images: 88
Postby Bikeneggs » Tue Mar 19, 2024 12:33 am
We bought a 9 year old TD on a Chinese made HF chassis. Former owner had upgraded from stock 4 ply B rating to 6 ply C rating 4 lug tires and wheels so she could "tow at higher speeds". Tire sizes have remained at 4.80-12. Fully loaded for the road the trailer weighs 800 lbs. This summer we plan to tow the trailer behind our 2000 Sienna (seats 4 but sleeps 2) from CA to TN and back taking the hot southern route. How fast can the C tires (990 lbs, 90 psi) be run for covering 400 miles at a time, especially through Texas? The Sienna's V6 AT runs best above 60 MPH. Towing at 55 mph with OD off revs the engine too high and fuel economy drops tremendously (16 mpg). What towing speeds are reasonable through those states without attracting attention?
Internet results for speed ratings shows B at 31 mph and C at 37 mph, well below highway speeds I envision.
Bikeneggs
Postby working on it » Tue Mar 19, 2024 11:28 am
Bikeneggs wrote:We bought a 9 year old TD on a Chinese made HF chassis. Former owner had upgraded from stock 4 ply B rating to 6 ply C rating 4 lug tires and wheels so she could "tow at higher speeds". Tire sizes have remained at 4.80-12. Fully loaded for the road the trailer weighs 800 lbs. This summer we plan to tow the trailer behind our 2000 Sienna (seats 4 but sleeps 2) from CA to TN and back taking the hot southern route. How fast can the C tires (990 lbs, 90 psi) be run for covering 400 miles at a time, especially through Texas? The Sienna's V6 AT runs best above 60 MPH. Towing at 55 mph with OD off revs the engine too high and fuel economy drops tremendously (16 mpg). What towing speeds are reasonable through those states without attracting attention?
  • 1) How old are your tires? how recently have the wheel bearings been greased? do you have an infrared temperature gun to measure the temp of your tires and wheels?
    If you're planning long sustained speeds on hot highways (especially thru West Texas, New Mexico, Arizona, and eastern California (i.e., the hot southern route), then you'll need tires & wheel bearings in good shape, and check your temperatures along the way.
    tire & wheel bearing temp monitoring.jpg (79.18 KiB) Viewed 6037 times
    temperature guns can be bought at big box stores or Amazon, at prices from $8-$300
    infrared temperature gun.JPG (66.54 KiB) Viewed 6037 times
    I carry my Greenlee temp gun in my tow vehicle for camping (or in any of my vehicles, on long trips, especially in summer), and check temps whenever I stop (sometimes just for checking the temps). I've done that for nearly thirty years (or at least as long as I've had that device), and I found and fixed a dragging trailer brake (on my race car trailer) before it caused a heat problem with the bearing. They're worth the cost just for finding a heat problem, and I've used mine for engine & cooling system diagnostics, too.
  • 2) You're confusing the "C" tire load rating with the speed rating, when you say the internet states 37 mph for your tires. You also have said that your tire has a "M" speed rating, which is actually 81 mph.
    tire speed ratings from Discount Tire.JPG (64.72 KiB) Viewed 6037 times
    Texas highway speed limits are most commonly 70 or 75 mph, but some stretches of I-20 in West Texas are 80 mph, and there's one one stretch in Central Texas that's posted as 85 mph: "Texas 130 between Texas 45 near Austin and Interstate 10 in Seguin has a posted speed limit of 85 miles per hour." You'll find that most drivers go a bit faster, but I'm usually towing at 72-75 (depending on traffic) because my '04 Chevy 2500HD tow vehicle likes that speed range best. Since it doesn't notice my squareback trailer behind it, my gas mileage doesn't increase much, no matter what. YMMV
173193172890148599
working on it
Images: 457
Postby Bikeneggs » Tue Mar 19, 2024 10:59 pm
" infrared temperature gun to measure the temp of your tires and wheels"
Thanks for sharing your experience with an IR temp gun and range to look for. Will definitely bring my along. I also appreciated your observations of speed limits which I assume are legal when pulling trailers. If I can run 60 mph without being pulled over I'll be happy.
Just repacked wheel bearings - I think this was the first time the inner bearings have been serviced in 9 years, but they look good.
Don't know anything about an "M" rating on the tires. Originals were B rated and the upgrades are C rated. Will bring both originals along as spares, hoping to mount them underneath the floor between the chassis spars closest to the axle.
Bikeneggs
Postby working on it » Wed Mar 20, 2024 10:23 am
Bikeneggs wrote:...Don't know anything about an "M" rating on the tires. Originals were B rated and the upgrades are C rated. Will bring both originals along as spares, hoping to mount them underneath the floor between the chassis spars closest to the axle.
"Sorry about that, Chief" (do any of you...other than us old guys... remember where that quote is from?), I guess I mixed up my research when posting that. I had four or five TnTTT threads open, plus another four or five other websites, too, so I got my reference wrong attributing the "M" tire rating to you, Bikeneggs. Otherwise, every other item in that post is correct.
173193172890148599
working on it
Images: 457
Postby QueticoBill » Wed Mar 20, 2024 6:57 pm
"Get Smart"
QB
QueticoBill
Images: 22
Postby Tom&Shelly » Thu Mar 21, 2024 7:25 am
QueticoBill wrote:"Get Smart"
Thought he said "other than us old guys" Bill! :lol:
172912 170466 173366
Tom&Shelly
Palladium Donating Member
Images: 2023
