Juneaudave wrote:Yes I know I'm not supposed to do this...but...my friend brought over his buzz box stick welder today so I could weld up my trailer. It needs a 30 amp 115 circuit (so the plug is wrong). Assuming a fella is smart enough not to burn down his house, and the welder is rated at 26 amp, do you figure I could swap out a 20 amp circuit recepticle to a 30 amp recepticle for a short time? I have a 50 amp 220 circuit to my shop, but no 220 welder...constructive thoughts? Alternatively, I guess a fella could rent a generator for day...Having it welded in a shop is not in the cards due to cost and...quite frankly...I want to do it myself!!!
Juneaudave wrote:Thanks Guys...I wasn't worried about burning the house down, I was more worried about popping breakers (Nitetimes...BTW...I agree it would work but a fella ought not!!!)...Shucks, a cheap guy like myself has to improvise.
The solution is in what I forgot...when I put in the 50 amp 220 service about ten years ago, it was to give enough juice for my wife's pottery kiln. I had 30 amp service to the box then, but changed out the breakers and the box, and ran a parallel line when I upgraded to 50 amps. The 30 amp line is still stubbed out...a bit of box work and a new recepticle and I should be in business.
Thanks...Juneaudave
Users browsing this forum: Bing [Bot] and 3 guests
