Skip & Mike::)
I appreciate the pictures and both of you for explaining this critical
modification to trailers that many have and will do in the future.
Given that the goal of your modification was proper door clearance &
weight distribution for the build of a Teardrop. I would like to point to this
thread as a well documented example of how one goes about moving back
the axle. This thread surely addresses how to move the axle with pictures
to accommodate tongue weight as well as door positioning issues resolved by
this modification of the standard build of a utility trailer.
Thank you for taking the time to show me exactly what you did. I am sure
there will be others in the future that will learn from your efforts.
I will be pointing to this thread in the Trailer and Chassis Secrets forum.
T&TTT Forum Suggests 5 Trailers for New builds HERE~
This is the NOTE: that will be at the beginning of the Trailer page::thumbsup:
Note: Building a Teardrop Trailer?
You may want to consider modifying the standard utility trailer axle
position back to facilitate door clearance & accommodate tongue weight
distribution for your Teardrop trailer build. Go here to see pictures and read how to modify your new trailer by moving
the axle back.
