Trailer Frame Slightly Bent. Am I screwed?
Postby sandman » Fri Mar 23, 2007 8:57 pm
Cool Deal, Guys. Thanks for holding my hand through this. I checked the trailer a little while ago and it's bent back a bit more since this morning. It's slowly getting straight.
sandman
Images: 154
Postby sandman » Sat Mar 24, 2007 10:35 pm
An update to the trailer saga, I began to work on the trailer again today and decided that the metal mesh was in the way and causing some issues with getting the floor level so I took a grinder and cut-off wheel after the mesh. I left the first five feet for the cargo deck and cut the remaining 7 feet off and grinded the welds down. The floor joists are now sitting very level so I can start bolting the floor down tomorrow. Looks like the bad Ju Ju is finally starting to pass. 8)
sandman
Images: 154
Postby toypusher » Sun Mar 25, 2007 7:25 am
That's great to hear. Just keep it up on the jacks until the whole body of the tear is done.
toypusher
Images: 324
Postby madjack » Sun Mar 25, 2007 10:40 am
SM, I wondered when you were going to realize that about the mesh...better sooner so it could be removed instead of latter when it couldn't............
Postby sandman » Sun Mar 25, 2007 10:46 am
Yeah, I will be keeping it on the jackstands until the end of the build. The extra height is easier on my old back. :)
Madjack-I figured that the mesh would provide nice level support plus make the trailer more rigid but it really didn't. It was just in the way the whole time. Got a few more welds to grind down but lesson has been learned plus removing the mesh took about 60lbs of worthless weight off the frame. :thumbsup:
sandman
Images: 154
