My setup is with the Prodigy on my 4runner and TD. My 4runner is a manual. I have had zero problems.
sushidog wrote:I chose the Primus proportional brake controller by Tekonsha. It's got the same circutry as the Prodigy, but is easier to set-up.
Section 8 wrote:...My vehicle is a 2006 Wrangler Unlimited. It has a manual transmission, so when I want to coast the trailer brakes might come on (I read that high drag vehicles with manual transmissions will "trick" these controllers when letting off the gas at highway speeds) particularly with the high engine revs aiding compression braking.
Also, for off roading pursposes, I want extra hill holding with the trailer, instead of having it try and push me down steep inclines, so when I am on the brakes, the trailer is braking too, even when I am not moving. Lastly, with a high pucker factor (and at times the conclusion of the above problem) you get the best braking on loose surfaces at low speed when your tires can lock and start furrowing the surface. In these cases, with out ABS, with a trailer providing no brakes behind you because you are sliding at a constant (albit slow) velocity the trailer will push you faster and likely jack knife. This I have witnessed a few times in the winter on steep boat ramps coming onto a frozen lake, with and with out ABS, and witnessed several WHOOOAAAA!!!!s through the windshield on faces as it almost happend.
This is why I would like a hydraulic pressure sensor, but the pedal sensor would be OK....
