Torsion Axles: welding to frame versus bolting
Postby angib » Fri Feb 24, 2006 1:57 pm
Bandit wrote:Does anyone see a problem with this?
I don't - it sounds perfectly workable to me.
You might want to work out a way to seal the unused bolt holes, including the ones hidden by the axle brackets, to avoid too much corrosion inside your frame.
Andrew
PS You have to scroll down the home page of my web site (Design Library) to find the 'Trailer Balance' item.
angib
5000 Club
5000 Club
Images: 231
Postby Bandit » Fri Feb 24, 2006 3:50 pm
I plan to mount the axle with the bracket, both bolted to the frame and welded to the frame. After I complete the build, I will adjust the axle for tongue weight and then seal the unused holes with silicon. This should seal the tubing against moisture, but still let me use the holes if I need them in the future.
First Metal Cut 02/11/06
Complete! (Almost) 08/22/06
Looking for a trip in the SPRING!!!!
Not Up to Testing the Heater!!!
Thanks for all the HELP!!!!
Bandit
