When purchasing 2"x2" x 1/8th inch wall tubing for the chassis frame is there any specific grade or identifying / specification metal I should be using?
Thanks.
John
Capebuild wrote:Any answer to the previous question? Thanks
Also...new question.... regarding the 60/40 rule for axle placement. Is that for measurement of the just the chassis.... or do you take the actual cabin dimension into consideration? For instance if my cabin body
sticks off the back of the chassis by 10 inches, say, does the 60/40 rule apply to where the cabin ends or where the chassis frame ends? Or maybe it's unwise to have the cabin stick off the chassis like that? Thoughts?
Thanks
extensively, expanding it (adding lines of the formula as to weight and placement) to cover all weight additions I made to my trailer, which helped me keep track of the balance on my trailer, even before actually weighing it. I knew it was going to be too light on the tongue, before I could find the right tongue box to compensate for a bad axle-to-frame placement: 51 " forward/45" rearward (I extended the original frame too far in back, too little in front, with a lot of weight in the rear storage area).pchast wrote:There is a spread sheet to verify it. Actually it just depends on everything you do and how you load.
Check it out. viewtopic.php?f=35&t=59449
