Those of you who have used the HF trailer frame -- have you positioned the axle as in the directions---- under the spring hanger or did you reposition it between the spring hanger and the side rails?
Thanks Philip
brian_bp wrote:..........Notching the frame is another matter entirely... that kills a significant part of the strength of the frame, at a kind of important place. When people lower street rods (usually pickup trucks) and notch the frame to provide axle clearance, they also add reinforcement.
toypusher wrote:The frame proper does not have to be notched. Only the bracket that positions and holds the spings and axle in place on the frame.
